Home > Technical (L322) > Intermittent exhaust temperature sensor fault? Any advice?
GTTURBO87UK
I keep getting limp mode and the fault code p042D-00. I had a dpf issue so had that gutted and sent the ecu off to have an egr and dpf delete done. I keep getting this fault coming up now saying bank one sensor 2 input too high. I think that’s the sensor near the dpf. I disconnected the sensor and it’s exactly the same. I thought by disconnecting the sensor it would have had engine management light on and limp mode straight away but it doesn’t. I’m a bit stuck on where to go so any ideas would be great.
Post #626318 16th Mar 2022 4:28pm
GTTURBO87UK
Is there anything I need to do after refitting the ecu? I was told the egr blank is just done through the ecu
Post #626320 16th Mar 2022 4:31pm
Neanderthal
My understanding is that there's a physical blanking required.
Loads of posts about it and EGR blanking kits available to buy. Makes sense that it should be blanked if deleted.
This is a related post; https://www.rrsport.co.uk/forum/post581812.html
Post #626359 17th Mar 2022 5:55am
GTTURBO87UK
Blanked the egr still getting this dam fault intermittently
Post #626391 17th Mar 2022 3:44pm
DrRob
Those kits are for the 3.6 not the 4.4 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #626407 17th Mar 2022 7:32pm
GTTURBO87UK
The exhaust temperature sensor on the dpf needed to be deleted
Post #626896 24th Mar 2022 12:01pm
