Home > Maintenance & Mods (L405) > Wind noise through drivers window.
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
Just picking brains if anyone would no a way to make the drivers window go up a bit more, i have had some wind noise coming in through the top of the window for some time and it seems like it needs to go up a touch more, i tried dropping it down them taking it back up and holding the up button for a cupple of extra seconds as i seem to have in mind i have seen that works somewhere before but no luck with that. Any info would be great. Thanks
Post #626494 19th Mar 2022 5:38pm
RRVSE-2
United Kingdom 2017 Range Rover Vogue SE SDV8 Balmoral Blue
Are you sure its the window, l had a similar noise and it turned out to be a loose a pillar trim. Keith
Main car : FFRR L405 Vogue SE SDV8 Balmoral Blue
Main M/C : Ducati Multistrada 1200S
Other
Suzuki Jimny
Past Cars
Ford Fiesta Titanium
D4 Nara Bronze HSE
D3 Teal S
Post #626497 19th Mar 2022 6:17pm
Edgey808
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
I have the very same issue, but seemed to have fixed it by bending the top frame in towards the roof. Sounds harsh but it works….
Over the last few weeks, i have very carefullly wrapped a log in a towel, placed this on the base of the door frame, side step, wound the window fully down (drivers door) and then proceeded to place some gentle force on the top part of the door frame. Shocked
I have to admit its certainly working for me as the wind noise is greatly reduced, I just need a bit more adjustments to obtain the expected silence. Thumbs Up
Stephen
Post #626503 19th Mar 2022 8:51pm
knwatkins
I had this when I first bought my L405 (used). It was just the door seal rubber drying out. I ragged on a bit of Autoglym Bumper and Trim Gel, problem solved. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #626510 19th Mar 2022 11:31pm
Stephen
Open the door and with the window down place your knee on the top of the door panel, your hands on the top of the frame and bend it inwards... Its remarkably easy to bend it inwards Thumbs Up
Post #626513 20th Mar 2022 12:38am
154JON
Thanks Thumbs Up
Post #626657 21st Mar 2022 9:10pm
Edgey808
Stephen
Thumbs Up Perfect!
Post #626671 21st Mar 2022 10:54pm
