![]() | Home > Maintenance & Mods (L405) > Front differential fluid change |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1392 ![]() ![]() |
New Oil is cheaper than a new diff or gbox
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1416 ![]() ![]() ![]() |
Mine had its differential oil changed at four years/40,000 miles at my request. I was told that LR recommended it be done at six years, presumably about 60,000 miles (100,000km). It will partly depend on use when it is necessary. I have not had the gear box oil changed yet, but there will be threads on here about when it is thought wise to do it, I think maybe six years/60,000 miles. Maybe a search on the Getrag website would be useful too. Only Range Rovers since 1988 |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Obviously this is only my personal preference, I would change the oil in both diff's at the same time, usually earlier than recommended. Same with for the gearbox, do it earlier than quoted in the schedule.
ivo_markov Member Since: 21 Mar 2022 Location: Brussels Posts: 19 ![]() ![]() ![]() |
Yes, I wondered too. Probably because it has the active locking diff on the rear axle, as opposed to the normal one, and it is under heavier load, but I am only guessing.
There was no suggestion from the dealer that there was a difference between the differentials from a perspective of when to change the oil. Only Range Rovers since 1988 |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 778 ![]() ![]() ![]() |
The open diffs actually have a service interval of 160k miles or 10 years with the locking diffs at 80k or 6 years.
Here's a link to the servicing sheets for reference:
Many thanks! |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2281 ![]() ![]() ![]() |
I have changed diff transfer box gearbox every 30k miles - I have had it from 60k it is now on 220k all running fine cant remember where I got the figure from but it was on here as a recommendation from somebody anyway for me it is worth every penny |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 400 ![]() ![]() ![]() |
What is the oil that should be used for the diffs and transfer box? Current:
Diffs = 75W90 GL5 eg. https://www.smithandallan.com/products/tra...l-gl4-gl5/
LR part numbers for rear fiff and transfer case oils are LR019727 and IYK500010. |
