![]() | Home > Maintenance & Mods (L322) > Rear disc removal |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 946 ![]() ![]() |
Select neutral & of course ensure the parking brake is released |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 847 ![]() ![]() |
Did that. Came to a stop. Selected neutral. Ensured park brake not selected. Switched off ignition |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Try keeping the engine running when in neutral, when you turn off the car it goes into the park? |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
Do you not have to jack both rear wheels up? |
I seem to recall mine re-applied the EPB when leaving in neutral and turning the ignition off, so I think I left the ignition on whilst lining up the holes.
Could be EPB could be automatically applied when turning off ignition. Difficult to say really as the rotary gear selector withdraws flush and the lights go out.
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 205 ![]() ![]() ![]() |
Once engine is shut down automatically goes into park 2016 4.4 diesel |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1344 ![]() ![]() ![]() |
I agree with nicedayforit as long as the handbrake is off. |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
Make sure you have both rear wheels off the ground, this will then let you turn the wheels via the rear diff if all the brakes are free and H/brake released! If you have three wheels on the ground your going to really struggle due the 4x4 system.
I can jack up at the back using the central mount / jacking point
When l last did mine l jacked up both rear wheels and to get sufficient leverage on the disc l wanted to rotate l used a breaker bar between two of the wheel studs. Worked without engine or ignition on, indeed l can’t think of any reason why it wouldn’t. |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 299 ![]() ![]() ![]() |
Same here, jacked the back end completely and both rear wheels will turn. Car in neutral and EPB off |
Definitely don’t need ignition on to do this |
