Home > Technical (L322) > Noisy Fan noise from the Battery compartment?
Philclemo
Hi Guys and Gals,
Loving my new to me Westie. A few little niggles are coming to light now as 'we get used to each other'.
This one has been there since day one to be honest. There is a fan noise that comes in which is a bit of a howl, it's coming from the front passenger (left hand side) dash area at the bottom of the A post. What was alarming was that it was particularly loud with the bonnet up and appeared to be in the battery compartment. Is there a fan in there? The noise comes and goes but, I would be happier knowing what the issue is and possibly rectify it.
Cheers,
Phil RR Westminster 2012 4.4 TDV8 Orkney Grey
LR Freelander 2 TD4e HSE Stornoway Grey - gone but not forgotten
Post #627176 29th Mar 2022 9:25am
DrRob
Sounds like the Fuel Burning Heater to me. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #627179 29th Mar 2022 10:36am
Philclemo
Ooh, please expand. RR Westminster 2012 4.4 TDV8 Orkney Grey
Post #627180 29th Mar 2022 10:38am
mjdronfield
Sounds like that to me too. A bit like a jet taking off. The diesels have a fuel burning heater, in the wheel arch under the battery area. It comes on to help heat the coolant up under certain circumstances, as a Diesel engine doesn’t give out as much heat as a petrol one, generally speaking.
It can also be set using the screen, to come on and warm/defrost the car on cold morning. There was also the option of having a remote fob to turn it on and off manually.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #627186 29th Mar 2022 11:07am
mjdronfield
It’s in the passenger wheel arch, behind the liner….
There is loads of info in the Wiki…. Top right under the fullfatrr banner…
Joe90 did a brake line write up, and you can see the FBH in one of his pics….
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #627187 29th Mar 2022 11:21am
Philclemo
Thanks guys. I'll take a look at the Wiki (I do forget about TBH).
Post #627192 29th Mar 2022 11:48am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
There is also a fan on the ECU bolted to the battery, these fans can fail and make an almighty noise on the way out, very different sound to the FBH. Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #627213 29th Mar 2022 4:04pm
Philclemo
Thanks Caesium.
Update: I can confirm it is the FBH, I used it this morning as it was cool enough for it to kick in and yep, that's the noise.
Is there a fix or should I leave well alone?
Post #627294 30th Mar 2022 9:19am
Caesium
It should not be excessively noisy, its just a reasonably deep fan noise, accompanied sometimes by a little smoke and the smell of diesel. Christian.
Current Cars
2019 BMW X4
or
Post #627297 30th Mar 2022 9:24am
Philclemo
Yes, I wouldn't expect it to be too noisy it being the car it is but it does howl and it's audible in the cabin.
I'll see how it goes, it's likely to be kicking in over the next few days the way the weather is going.
Post #627299 30th Mar 2022 9:28am
mjdronfield
You can def hear it running, and has already been said, the exhaust for it is down where the front mudflap is or would go, and it will smoke from there occasionally.
It might also carry on for a bit after you turn the car off.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #627345 30th Mar 2022 4:33pm
