Home > Maintenance & Mods (L322) > Jacking |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 444 |
Please don’t take this the wrong way as I’m only pointing this out from a safety point of view, but if your struggling jacking it up due to knowledge then be very careful attempting suspension bushes as you need to support the suspension in the correct place as you remove certain ones. I taking your doing the outer swivel bushes which is popular on the L322. They’re not too difficult to do if you know what you’re doing but dangerous if you don’t, please be careful and also use proper axle stands |
29th Mar 2022 10:52am |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
You need to lock the suspension in access mode and open a door to stop the car from attempting to correct the suspension travel. Christian.
29th Mar 2022 11:35am |
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 93 |
No fair point mate always a good thing to consider H&S even for the seasoned DIY'er, maybe I was having a brain fart but I've previously had the wheels off on numerous occasions without issues and even my daughter who is a mechanic for the post office working on their fleet was stumped this time.
29th Mar 2022 11:36am |
Maybe that's what I had forget to do (I must be getting old or it was just a brain fart...) we're scheduled for another attempt next Sunday so I'll start off by dropping it and leaving the door open
29th Mar 2022 11:42am |
29th Mar 2022 12:18pm |
that looks about right, I think the issue was In my case the jacking point on the body didn't lift it as the weight of the wheel/tyre just pulled down on the air bag/frame etc so use the trolley/jack stands as per your picture.
29th Mar 2022 2:11pm |
As long as your shock absorbers are connected they will eventually stop the wheel dropping when they hit the stop, but it is a lot of travel before it does. The car jack will lift it but seems to go for ever. Use a trolley jack which is much easier. |
29th Mar 2022 4:37pm |
indeed, I was amazed just how much travel there was (thought the extended travel on my disco was good but I might even win the twist-off competition with the full fat at the next land rover show ) |
29th Mar 2022 4:44pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 2804 |
The central rear jacking point is quite high up. A sprinter jack on the outer plastic jacking sockets will lift the rear tyre well clear for wheel changing purposes but as I found you then have no way of putting an axle stand anywhere if you want to do anything repair related. 2012 TDV8 Vogue (L322) |
29th Mar 2022 8:29pm |
Roverte Member Since: 01 Dec 2021 Location: Connecticut Posts: 6 |
I've read through a lot of posts about this and seen the RAVE instructions but haven't been able to find a good picture that confirms where to place the jack and jack stands to raise the front. Here's a photo I took yesterday noting where I plan to put the jack and stands. (I've removed the plastic cover panel to see the subframe.)
6th Apr 2022 1:34pm |
Your picture shows where I jack mine up, using the crossmember.
6th Apr 2022 1:42pm |
Thanks. Does the under tray really not come off when the car is on the ground? I figured that I could pull it off and left it on only because I was taking a quick photo and wanted to be able to reinstall it more easily. |
6th Apr 2022 1:51pm |
I put my undertray on ( it was missing when I bought it) with the suspension in off road height and the drivers door open to stop it going down. 2012 TDV8 Vogue (L322) |
6th Apr 2022 1:56pm |
Thanks - that’s good advice. |
6th Apr 2022 3:50pm |
