![]() | Home > Technical (L405) > Oil sump drain bolt seized |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 778 ![]() ![]() ![]() |
The presence of a a sump plug has nothing to do with the fact it was earmarked for the F150.
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
Besides how else would you know the sump guard can come off. I swear it would've tested an Angel! Call me old fashioned but don't feel I know a motor until I've dropped the oil and had a look under her skirt😌 Help got CAR OWNER VIRUS! |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Had the sump guard off mine. It came off Ok.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1778 ![]() ![]() ![]() |
………… V6 Vogue - “Less is More” - less to go wrong! |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
get the mig out and weld a nut on . or get someone with a good socket and bar on nut and then give the flange of the bolt a hit with a chisel and hammer it has no mother or father so vidde hit the sod . new vehicle purchase
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 ![]() ![]() ![]() |
Not quite true. My 3.0 Mercrusier had a rubber pipe attached to the drain plug. The pipe would reach through the bilge drain plug and the sump could be emptied via the tube. 2017 5.0 Autobiography Supercharged 2005 Merc SL350 2005 Disco HSE 2.7 oil burner |
