Home > Technical (L322) > Heavy steering.
PeteT80
Heavy steering.
Hi, just come away for a few days away and 5 miles from arriving, steering felt heavy, plugged in IID and got B12FA-13 (2f)
Question is, is this an easy and cheap fix or something more technical?. Thanks.
Post #627729 4th Apr 2022 4:30pm
Discotigger
Have you tried clearing the fault and seeing if it comes back. Could just be an electrical gremlin. If it's the servotronic valve (solenoid) at fault, they're relatively easy to replace.
Post #627738 4th Apr 2022 5:38pm
PeteT80
Thanks. Fault keeps coming back as soon as I start the car. Would it be ok to drive the 170 miles back home on Friday then get it sorted when I get home?
Post #627747 4th Apr 2022 7:30pm
Discotigger
Yes it should be ok to drive it if you take it relatively easy, the steering will be heavy but shouldn't lock up. Might be a good idea to check the wiring to the Servotronic Valve, it may have a break somewhere which could be repaired. Have a look in the Wiki for the Workshop manual, it'll have a description of steering components and diagrams to help identify the components and locations.
Post #627762 4th Apr 2022 8:57pm
PeteT80
Will do, thanks for that.
Post #627771 4th Apr 2022 9:48pm
