![]() | Home > Wheels & Tyres > Polished Wheels 'Style 12' |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 929 ![]() ![]() |
Pretty sure these will be media polished, opposed plated / painted etc |
RRABNara Member Since: 02 Mar 2022 Location: SW3 Posts: 31 ![]() ![]() |
what do you mean for "media polished" ?
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Are they not diamond cut and lacquered? Christian.
no they are not diamond cut as you cannot see any "ray" tipical of diamond cut
As the Range Rover is recess cut into them and diamond cutting is 1/1000ths of an inch material removal they absolutely can be diamond cut.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1419 ![]() ![]() ![]() |
My 2012 WM had the same. They are polished and then lacquered. Alas the finish is prone to getting 'runs' of corrosion under the lacquer. I had the first set replaced under the corrosion warranty when that happened, but it was not long before the second set started to go the same way. The sparkle silver painted alternative might be more durable, but if you like the look then i suspect you'll need to keep refurbishing them fairly regularly. Only Range Rovers since 1988 |
As an example, here’s a company that performs this type of work - no connection whatsoever! https://www.ebay.co.uk/itm/181591457667?_t...BMiKWA__9f |
