Home > Technical (L322) > Not reaching operating temperature after thermostat change |
dimetrius Member Since: 20 Apr 2021 Location: St. Petersburg Posts: 24 |
Update:
23rd May 2022 12:48pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 2982 |
The speed of the water pump will be determined by the size of the pulley and the engine speed so I'd be really surprised if it was spinning too fast. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
23rd May 2022 1:34pm |
Thanks for your response dhallworth!
6th Jul 2022 12:20pm |
we've also replaced the headgaskets and I wonder if it's at all related 2009 Range Rover Westminster 3.6 TDV8 Alaska White/Jet |
6th Jul 2022 12:21pm |
If you've done all that work to it, is it possible the temperature sensor has had a knock and isn't reporting the temperature properly? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
6th Jul 2022 12:27pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1116 |
Is the heating inside the car working normally? If so dhallworth's suggestion is a good shout.
6th Jul 2022 1:08pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
Have you scanned it to see what codes are there? |
6th Jul 2022 1:22pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
My 4.4 TDV8 showed up to temp on dial but wouldn't fully initiate DPF cleaning as it was keeping the engine temp too low by being open all the time due to the thermostat housing being damaged by a servicing garage and reading it was hotter than it actually was. Turned out the housing had been cracked and damaged - a sign of this was the fan being on most of the time, trying to cool an already cool engine!! . |
7th Jul 2022 11:54am |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 |
Does the tdv8 have also gearbox oil cooler like earlier bmw L322? If yes, then there is thermostat inside there and when it’s stuck open you have exactly those symptoms. Take Hella/Behr part. |
7th Jul 2022 2:04pm |
Yes, no errors. We also replaced thermostat in the new thermostat case that we replaced earlier, LOL. Checked the whole system a few days ago, including the new pipes.
Actually, no - I noticed the heating became rather faint. My mechanic pondered it could be webasto valves if I understood him correctly. But what dhallworth is suggesting makes a lot of sense, thank you!
Yes, in my case the housing was cracked as well, although I didn't experience the symptoms. We've replaced the housing as well as the fully functional thermostat inside the new one just in case.
I don't know, but I will discuss this with my mechanic. Thank you all for your suggestions, I will talk them with my mechanic and report back on our findings! If anyone can suggest anything else before I take the Range to the service for the third time with this - please do! 2009 Range Rover Westminster 3.6 TDV8 Alaska White/Jet |
11th Jul 2022 10:00am |
