Home > Technical (L322) > Paint for front grille 2003
Slow progress
Morning all.
I’ve just bought a replacement front grille for my 2003 FFRR to replace my broken one, it’s intact and in good condition…except it needs a little paint.
Does anyone know the correct paint code? (Also is it the same for the door handles?
Secondly what prep needs to be done on the plastic for the paint to take?
Thankyou in advance for your help.
Dave L322 TD6 2003
Epsom Green- the dogs car which has worked it’s way into being the family car 😮
Post #628420 12th Apr 2022 8:06am
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
hi the paint code is under the bonnet on a plate . it is norm 3 numbers the handels should be the same colour coded with the car . paint code for epsom green is lrc 961 if this is the car you still have . prep for the grill and handels . i would scotch brite for a key then panel wipe . use a self etch or a plasto primer i would use plasto my self it is clear it has a very strong smell so mask up make sure you do the edges as well and then on with the base coat colour just a nuff to cover and do not over do it you are not looking for a high build on plastic then with in 20 min of putting base on get a clear coat of lacquer let that go for 5 min and put a second coat build it up to a high gloss leave dry overnight . if you take a colour match from the car and take it to a paint shop they will scan it and should give you the right shade of the base coat and mix it and put it in a spray can for you . that is if you do not have any spraying gear . new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #628421 12th Apr 2022 8:37am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
Trim paint codes aren't identified on the car.
I think the grille, vents & door handles are "Brunel" grey if they're the same as my 2006 car.
It has a paint code, BLVC LBO, Paint Colour Description - Brunel Grey Silver Chrome Matt
It's not easy to buy - as only specialist paint supplier make it up.
I bought some from a company off ebay, but it was so long ago ebay has wiped it from my purchase history.
I think I had to search for the paint code rather than its name
The supplied paint was a great match & looks great Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #628426 12th Apr 2022 9:21am
mjdronfield
Didn’t someone find a Mercedes colour that was pretty close, or was that the silver grey on the inside trim panels?
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #628432 12th Apr 2022 9:58am
oggy
to save messing with paint go on to powerfuluk . com and buy the grill and door handle covers with the right colour format as pawl has explained or take the old grill to a paint shop and get it matched. new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #628433 12th Apr 2022 9:58am
https://www.fullfatrr.com/forum/post16377.html
Post #628440 12th Apr 2022 10:33am
Pawl
That's probably the post I got my info from originally Very Happy Paul,
Post #628444 12th Apr 2022 11:43am
francy
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
hi PM PANELS WARRINGTON will make paint for grill
Post #628490 12th Apr 2022 7:39pm
Brunel is the colour of the later, post 2006 fatties...
This was the closest to the original 2003 colour I could find...
Some pictures at the end of this thread....
https://www.fullfatrr.com/forum/topic27260-30.html
Thumbs Up Pete
-Click here for Thread-
Post #628542 13th Apr 2022 9:32am
Slow progress
Thanks Haylands will give that a go as the handles need doing as well as the grille L322 TD6 2003
Post #628674 14th Apr 2022 2:02pm
