![]() | Home > Maintenance & Mods (L322) > Thoughts? Has anyone upgraded the electrical BIG 3? |
Ajmngn Member Since: 25 May 2021 Location: Cambridgeshire Posts: 210 ![]() ![]() ![]() |
After quite a bit of YouTube and wider research into electrical starting/charging upgrades, there seems to be a lot of chatter about upgrading the so-called BIG 3:
Thanks for the input! I agree that engine block to chassis is the easiest and likely biggest ‘upgrade’ from the factory parts. I will be doing this as a minimum without any doubt! Andy
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3390 ![]() ![]() ![]() |
If it's not broken then why fix it? By all means check and clean any connectors but the wiring itself will be designed to carry more ( much more) than the maximum load as a designed in safety margin. 2012 TDV8 Vogue (L322) |
TDV8 Paul Member Since: 30 Nov 2020 Location: Tadworth Posts: 224 ![]() ![]() ![]() |
As above, if anything I’d probably check and clean the connections, but unless I physically saw anything wrong with the wires I doubt I’d bother changing it all 2009 (2010 MY) 5.0 Supercharged Autobiography
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 795 ![]() ![]() |
I have no faith in that being the case, you just need to look at things like the mild steel brake lines to see examples of penny pinching. I would expect that the cables will be the absolute minimum that they need to be. |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494 ![]() ![]() |
I don't think that's true.
You might be right, I'm no electrician but my 1st 3.6 needed a new underbonnet harness fitted at 8 years old because of corrosion issues |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
I replaced the loom on mine a couple of years ago as there was some internal corrosion on the cabling bit of a pig but all doable.
