Home > Maintenance & Mods (L322) > Droning noise when turning right and slowing down |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4237 |
Could be CV joint or prop shaft maybe? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
16th Apr 2022 5:02pm |
Happydaze Member Since: 30 Aug 2021 Location: Wirral Posts: 47 |
My bet is that it'll prove to be a wheel bearing, despite them having been checked out. I have a ffrr but haven't ventured into much of it but based on my wife's Shogun, which seems to eat front wheel bearings, I've found bearings can be noisy and pass genuine mot's, and although not sure, I suspect the ffrr design isn't much different to the Shogun, which is very different to a setup on a typical rwd car.
16th Apr 2022 7:18pm |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 294 |
Yeah I hope your right to be honest I’m still convinced it could be a wheel bearing might just bite the bullet and the front 2 replaced. I hope it’s not transfer case related then again it would make the noise on turning left and right if was surely.
16th Apr 2022 9:11pm |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 511 |
I had a Disco 4 making similar noises. Wheels off, proper thorough check. Wheels on, pulling and pushing, no play whatsoever.
16th Apr 2022 9:55pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
Had a 330 bmw, was sure it was the diff whining, wheel bearing in the end was the culprit, another vote for bearing here |
16th Apr 2022 10:09pm |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1142 |
Had a slight droning noise when turning one way........
17th Apr 2022 10:01am |
