Home > Maintenance & Mods (L322) > SGS trolley jack, opinions please
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I've been looking for a trolley jack to replace my old one.
I was initially looking at aluminium ones for the weight saving and came across this steel one
https://www.sgs-engineering.com/tj25-4x4-trolley-jack
Strangely its lighter than their 2.5t aluminium jack, has rapid lift and a higher max height oh and its quite a bit cheaper.
I just worry that it may be more unstable when using the high lift device, despite the fact that I know and trust SGS.
What do you think? has any one used one?
Thanks
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #628064 7th Apr 2022 11:32pm
Davlyn
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Funnily enough I'm in the same boat as you and in need of a new TJ. Have you spoken direct to SGS to get there take on suitability?
Post #628082 8th Apr 2022 10:10am
kevinp
I thought it looked like one of them short chassis ones but it is 620mm long so I'd say it looks a good one Dave.
Post #628085 8th Apr 2022 11:13am
johnboyairey
I recently needed a jack that would work on my Rangie, and my sons m sport Bmw which is a Censored to get a standard jack underneath... ive had it with the short trolley jacks, as they have limited width, the pumping angle is awkward, as really low..and sometimes don't look comfortable at height, with a wheel off the ground! so I bought this, as its wider, a little longer, and has quick-raise to get the cup up quickly, and a high load capacity at 2.5 tonnes, and I bought a rubber pad to go in the cup too. works great, such a step up from the shorter ones.
https://www.ebay.co.uk/itm/234296304930
Post #628095 8th Apr 2022 1:20pm
bigbo
Just to finish this I purchased the SGS jack.
A great price for such a well built trolley jack, it does the job very well.
However the combination of SGS and DHL is abysmal ordered Sunday so expected Tuesday delivery, but got an email from DHL that they will deliver Wednesday. Wednesday arrived and I got an email from DHL saying delivered and handed to David, not possible as I was out at the time.
When I got home and looked at the DHL website there was a proof of delivery photograph but no sign of my parcel.
2 hours later there was another entry saying the parcel was at the DHL depot.
55 minutes to get through to SGS customer services only to be told its with DHL. what a waste of time.
On Thursday I get a message that my parcel is delayed by 24 hours. Later that day I get another message that they will deliver on Saturday! That's not 24 hours.
So I think that I wont bother using SGS again, I could have walked to their site and back in less than an hour or so.
Very Censored off and rant over
MG TF 2003
Post #628826 16th Apr 2022 10:29pm
Gremlin500
………… V6 Vogue - “Less is More” - less to go wrong!
Post #628827 16th Apr 2022 10:46pm
Bingo_123
Hi bigbo, I also looked at the same jack few weeks ago as the 3t one wasn't in stock.
Good to know it's working well.
Couple of questions
Did it come with a rubber pad
Have you jacked up from front and back both. Do you have sidesteps.
Thanks
Post #628846 17th Apr 2022 8:30am
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
Also on the lookout for jack and axle stands. Is this package suitable?
https://www.sgs-engineering.com/tj3x-js-3-...cs=71v4ng2 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #628940 18th Apr 2022 9:43am
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
It’s what I’ve got, works a treat. Get yourself a rubber pad to fit in the jacking point and you’re good to go, pads available on the bay for peanuts
Post #628978 18th Apr 2022 2:35pm
Kiss My Carbon Footprint
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
As Jules says, should be fine.
But I note the Blackpool contingent to your current stable.
Speaking from experience, she might thank you for SGS' low profile trolley jack offering, again 3 ton.
I have one of these and also an equivalent branded as "Arcan".
With regarded to jack pads, see photo.
On the left, the one I've used for the Griff outrigger corners.
On the right, the raised lozenge matches perfectly the outer jacking points for the later L322s and possibly also earlier cars.
Both plentiful on eBay.
Warwick 2011 L322 TDV8 A/b Orkney Grey
2008 Defender 90 XS TDCi Java Black
2002 L322 TD6 Vogue Zambezi Silver (gone but not forgotten)
And one or two bikes - Ok, maybe more than one or two....
Post #628982 18th Apr 2022 2:56pm
RR2B
Thanks JoolsB and Kiss My Carbon. Re the Griff, I have a Halfords low profile but as it's 20 years old not sure I can trust it to lift the L322. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #628997 18th Apr 2022 6:28pm
Bingo_123
But this jack has max lifting height as 465mm, is it sufficient to lift the ffrr.
Post #629042 19th Apr 2022 8:38am
JoolsB
Lifts mine, get the FF in off road height and open a door and it’ll lift the wheels from the jacking point, if you’re just doing a quick wheel change then jack it under the suspension arm.
Used under the central jacking point it will lift both wheels clear.
Don’t forget your axle stands if you are going underneath.
Post #629065 19th Apr 2022 11:19am
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
Wouldn’t access height be better than off road height?
Post #629073 19th Apr 2022 12:23pm
Lance,
For the sake of the suspension airbags, I think you're probably right.
I would tend to lift initially using a jacking point. And then add a second jack to lift a suspension arm as required, adding a stand once the arm reaches the height required.
Tyre shops I've used tend to do something along these lines.
Although of course they perhaps don't bother with axle stands.
Post #629074 19th Apr 2022 12:37pm
