Home > Maintenance & Mods (L322) > Restricted performance
Katy90xx
United Kingdom 2012 Range Rover Westminster 4.4 V8 Baltic Blue
Morning all
I have a 2012 RR Westminster 4.4V8, in the last week it’s been in the shop for new power steering pipes, brake pads, anti roll bars and bushes and exhaust sensors. We got it back last Saturday when it decided there was a problem with the suspension, back in the shop…can’t find anything wrong so all sensors recalibrated and we’re good to go. Driving it yesterday (50mph tops) we now have a restricted performance warning so limited to the 3,000rpm. Lots of googling later I’m not sure I’m any the wiser on the most common causes for this issue? No noticeable noises/shudders, no engine warning lights, can’t see any noticeable leaks (parked on driveway no puddles underneath)
Any advice greatly received!
Post #628769 16th Apr 2022 10:09am
kevinp
First check on these engines are the 4 rubber manifold inlet hoses. Should be clean and dry. If they have black soot on them they will be leaking.
Post #628774 16th Apr 2022 11:07am
DrRob
Which garage are you using ? I’m close to Winchester so can recommend a decent place for you.
Avoid all main dealers to begin with Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #628796 16th Apr 2022 5:03pm
Fox889
There doesn’t appear to be a link between the work you’ve had done & the problems you’re now having, apart from the exhaust sensors (why?).
So, as kevinp has said, check the four donut hoses. While you’re there, undo the MAP sensor (small torx screw on top of the plenum) see what the sensor looks like and also where the MAP sensor sits, that can also get clogged up.
If you were gunning the old girl up to 50mph and above 2700rpm the second turbo actuator could be gummed up & not allowing the second turbo to operate.
Just my thoughts, they may or may not help the situation.
Keep us informed, and by the way, Dr Rob makes a very very valid point! 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #628842 17th Apr 2022 8:05am
Furnitureman
United Kingdom 2012 Range Rover Westminster 4.4 V8 Cairns Blue
I used to get restricted performance on start up or occasionally on a drive but the car drove like normal turned out a new battery fixed it as the old one was struggling, may be worth a check 2012 Range Rover Westminster 4.4 TDV8
2006 Discovery 3 HSE 260k miles and still going strong with a new owner
Post #628928 18th Apr 2022 7:36am
DrRob
A one post wonder...never to be seen again Whistle Rolling with laughter Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #628934 18th Apr 2022 8:53am
Fox889
Laughing 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #628948 18th Apr 2022 10:54am
