![]() | Home > Technical (L322) > Brake fluid change |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic44822.html 2012 TDV8 Black Edition
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3986 ![]() ![]() ![]() |
Changing the brake fluid is almost exactly the same as bleeding the brakes, the only slight difference being that you keep bleeding a particular wheel until the new fluid is expelled. You will know as soon as the new fluid comes through by the obvious clean colour. The only thing you have to be careful about is not letting the fluid level in the reservoir drop too low.
Davlyn Member Since: 21 Nov 2011 Location: Sladesbridge, Cornwall Posts: 236 ![]() ![]() ![]() |
Thanks guys. All seems straightforward enough. |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 672 ![]() ![]() |
When we did the L322 we used SDD which purged the ABS module which also directed you in terms of the sequence, not sure if it made a huge difference using SDD but the modules didn’t half make a racket.
From dhallworth in his thread
You can't just bleed the brakes in a conventional way as there is fluid in the ABS circuit that also needs to be flushed out. |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
The ABS circuit is the same circuit as the service brakes. All the ABS pump does, is interrupt the pressure to the wheel that has lost traction.
Thanks guys. Great support as usual. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346 ![]() ![]() ![]() |
The only reason I used the IID tool for mine is because the circuit had been completely drained down.
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 782 ![]() ![]() ![]() |
I use one of these when bleeding or flushing the brake fluid...
Ahh! Someone whose used one!
I love it and would never go back to old, traditional method of pumping the brakes. I've used it on a few cars now including my old L320, my current L405 and my wife's little BMW.
Great - thanks |
You need one of these...
Calliper was off for a couple of days and no fluid lost. Christian. Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
I did consider clamping them but was worried about damaging the rubber. Were yours all okay afterwards? Kev
