![]() | Home > Maintenance & Mods (L322) > sorry for being the newly with a issue |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
darrenwest1 Member Since: 22 Apr 2022 Location: essex Posts: 10 ![]() ![]() ![]() |
copied from above
With the 3.6 you have to suspect the EGR valves as likely fail 2012 TDV8 Vogue (L322) |
Is there any way to prove they are at fault. Thanks |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 490 ![]() ![]() ![]() |
The EGR valves are PITA on these, but just be absolutely sure your top turbo hoses are not split before you go any further. Take them off to inspect them, especially under the webbing on the N/S one, they do split for fun on these engines.
thanks mate . the noise was whilst running / yes it feels like it runs on 7 when warming up occasionally
just took the top turbo pipes off that go to the throttle bodies they are still perfect and no splits
Difficult to say without hearing it but certainly could be the EGR sticking, especially if you have the miss fire on warm up.
they where not the issue , I could see them clearly as took off the pipes |
the flapping noise is not there today . but the fault code re appears after 5 mins of running |
There’s no guarantee but it sounds like you do have EGR issues, I had similar symptoms on my 3.6 and was never sure even to the point where I changed them that they were the issue, but it did cure the problem once I did them, only difference mine did go into limp mode a couple of times, but would reset itself with an engine restart.
Can be blanked on a 3.6 with a simple kit
The drivers side one is all loose. The disc just rattles open and close |
pulled the egr apart , the guts are all in bits and the shaft is not connected anymore
