Home > Maintenance & Mods (L322) > Rear quarter rust / bumper hangers
BMG
United Kingdom 2002 Range Rover Vogue 4.4 V8 Bonatti Grey
Gave the car a proper wash and polish the other week, and found that the pimple of rust I spotted a month back on the n/s rear quarter, has grown to a larger scab of rust.
So with the long weekend, thought I'd take the bumper off and remove the inner boot trim and have a look. It's a bit grim...
Small on the outside
Large on the inside.
The o/s has no rust showingon the outside, but thought I'd better check the inside....
Not as bad, but not great.
Despite looking bad, this was surface rust and cleaned up back to fresh metal quite easily. On with some Bilt Hamber rust treatment and painted the next day, and later with some anti corrosion wax. Think I'll also add a small drain hole too.
Anyway, repair came out OK and looks to have been caught just in time.
As for the nearside, going to take some surgery I'm not capable of. Any US members breaking rust free dry state cars they can take a cut from ?
Also, anyone know what kind of fixings these are on the bumper hangers in the first pic ? Look like some kinda specialist rivet, is there an alternative ?
If you have a rust-free example and want to keep it that way, might be worth having a look. If you do and find the above style horror, don't blame me for the bill Thumbs Up
Post #629017 18th Apr 2022 9:22pm
JCW
The rivet part no. is KYQ100010 & differs slightly to a regular aluminium pop rivet in so much it has three ‘legs’ that open out on the rear side when pulled tight.
Post #629061 19th Apr 2022 10:48am
Ian928
Norway 2006 Range Rover Supercharged 4.2 SC V8 Java Black
How did you get that access?! I have tried to look int that space but the access is blocked with lots of electronics. Did you remove everything? My car is a 2006 SC Autobiography so may have more stuff than normal.
I need to change the arch, but it sure would be nice to have access like that while doing so. 2006 Supercharged
Post #629548 23rd Apr 2022 9:15pm
BMG
I ripped out nearly all the radio and nav stuff ( it's the out of date early BMW unit ) when installing an Android unit. On mine, the right hand side is just an electrical board that a few screws to remove.
The two holes in the bodywork house a large plastic box each side,which is just a vent for the boot, they clip in to position. The squeeze release tabs on the vent box are outside of the car. Easy to do with the bumper off, possible without removing the bumper I would think.
Link for the vent box I mention.
https://www.ebay.com/itm/255071309119
Post #629565 24th Apr 2022 12:10am
BMG
Many thanks !
Post #629566 24th Apr 2022 12:11am
