![]() | Home > Technical (L322) > 4.2 Supercharged PCV System |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1030 ![]() ![]() |
This is an interesting post, I think you should pop over to sister forum range rover sport lots of similar posts there. Iv just bought a 4.2 supercharged as possible replacement for the wife's D3 as the 4.2 is ulez
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3311 ![]() ![]() ![]() |
I know the pipe you mean behind the Supercharger. It's a rigid plastic pipe that pushes into a plastic collet with an o-ring underneath it and goes back to the brake booster. I rigged up a home made smoke tester and found that o-ring to be leaking.
I didn't know about that pipe connection, it's not the one I meant. Just check on rrs and the pipe I meant causing lean A and B codes.
I’m not really sure how to interpret them but to me these long term fuel trims look pretty good considering it spends a fair amount of time on LPG too.
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 612 ![]() ![]() ![]() |
David
I’ve Googled it several times and it seems that on a brand new valve you should be able to blow through it without restrictions in both directions as it’s spring loaded and closes at a certain amount of vacuum. 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Ah ok, didn't know that.
Done some more checking tonight.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Sounds like a good plan and I do like the smoke tester might adopt that idea if you dont mind |
Smoke tester finished this evening. Resistance wire wrapped around the wick and then fitted into the pot.
Full-fat-Lance Member Since: 06 Feb 2022 Location: Essex Posts: 149 ![]() ![]() ![]() |
Good work. Hopefully you’re now on the path to resolving the issue! |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
Excellent thread David. |
