Home > Technical (L322) > Air suspension compressor
Skeletor
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Java Black
Having an issue when I pump the suspension height up and down a few times it’s saying ‘normal height only’ plugged in the GAP and it shows compressor slow to fill.
I’m looking to rebuild the air suspension compressor
where’s the best place to get a kit from ?
2009 5.0 S/C
Post #629774 26th Apr 2022 12:16pm
Weegie
Here is best https://www.bagpipingandy.com/
He has a video to follow. John
GAP iiD BT-Sold
Post #629777 26th Apr 2022 1:40pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Also depends on what compressor you have as too wether you can do a rebuild on it some you cannot? I bought a kit from bagpipe and had to send it back.
Post #629783 26th Apr 2022 2:23pm
Skeletor
Ok thanks I’ll give them a try
Post #629785 26th Apr 2022 2:48pm
mark towill
Canada 2008 Range Rover HSE 4.4 V8 Stornoway Grey
You probably have the Hitachi pump . Just finished rebuilding mine which is an 08 lux HSE using X8R kit on your side of the Atlantic. I destroyed my cylinder head but you will probably be more careful than I was! Had to order another kit to replace the head which included a head, piston head sleeve and bearing arm. The bearing arm was from China and broke. I salvaged the aluminum head and put it on the Japanese bearing arm and it works great now. X8R kit included an updated aluminum dryer canister cover and better fitting. You might want to clean out the electric motor which is covered by x8R competition in a video
Post #629952 28th Apr 2022 3:30am
mark towill
The competition is 4x4AirSeals Hitachi or Dunlop Land Rover compressor rebuild
Post #629953 28th Apr 2022 3:57am
I had that error and it turned out to be a hole on the air reservoir. I found this out after replacing the compressor, twice Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #629960 28th Apr 2022 5:46am
