![]() | Home > Maintenance & Mods (L322) > 100 leds per reverse light brite |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1494 ![]() ![]() |
Just be aware as of Feb 2021, it's technically an MOT failure for driving bulbs to be changed to LED, unless the fixture itself is an LED unit. 2015 Range Rover Autobiography 4.4 SDV8 |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 397 ![]() ![]() ![]() |
hi gary that takes about five years before it gets down her in cornwall very slow going pace . and they are a fixed unit not a bulb replacement . thanks for the info anyway new vehicle purchase
peternicholls Member Since: 12 Mar 2022 Location: Stoke-on-Trent Posts: 36 ![]() ![]() ![]() |
REGARDS MOT- At least one reversing light must be fitted and in good working order otherwise it's a MOT failure.
That has nothing to do with the mandate re LEDs published Feb 21. 2015 Range Rover Autobiography 4.4 SDV8 |
that is sounding good peter so my 2007 old banger will be okay so 2009 on then new vehicle purchase
I went around for years with no reverse light on my 2004 focus 🙈🤠|
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Super - bright LEDs in my reversing lights for several years with no issues MOT wise. Previous cars:
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
Reversing lights can be LED
Unless of course you swap out the halogen bulb for an LED in your headlight on motorcycles ….
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
During my last MOT, they noticed that my reversing lamps were bright, I told them I had fitted LED bulbs, they were quite happy.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3346 ![]() ![]() ![]() |
I keep thinking about doing the reversing light mod as with factory tints on my car, reversing at night can be a little daunting if you're not sure where you are.
hi david i got them from aliexpress new vehicle purchase
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
@ oggy: can you provide a link please? I've looked on AliExpress and I can't seem to find them. Cheers. |
hi gyre8 the company i got them from was called golden sg car light store from ali 48 led per panel x by 4 59mm x 44mm panels if this is still no good let me know oggy new vehicle purchase
