![]() | Home > Technical (L322) > Fan belt shredded itself today |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352 ![]() ![]() ![]() |
Got around to removing the shredded belt the big belt is totaly shredded the small one looks to have just snapped and I’m assuming this then took the big one with it, when I bought the car it had its oil cooler replaced under waranty and I asked them to change the tensioner and belt as it was almost 9 years old they replaced the big belt but not the small one which was date stamped 2012 has anyone else had the small belt just snap like this taking the big one with it, I’ve checked all the pulleys and they spin freely with no noise or side to side play, the only one that is harder to spin is the AC it spins but not as easy as the others
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
what was the make i swear by gates belts now you are going to tell me it was new vehicle purchase
no idea it was dated 2012 same year car was made 2012 Range Rover Westminster 4.4 TDV8
so over 9 years old i think that belt has done very well new vehicle purchase
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2743 ![]() ![]() |
The pivot in the tensioner for the rear belt is prone to wearing which causes the belt to run forwards on its pulley eventually running off the pulley. Non-genuine tensioners are known to be sloppy which causes the belt to tend to run off the front. |
It had a genuine tensioner and main belt 13 months ago, I’m assuming the small belt snapped and got under the rear belt taking it with it, not sure weather to go to my stealers for full genuine or advanced factors or Duckworth’s for the parts 2012 Range Rover Westminster 4.4 TDV8
The small belt is meant to be cut to gain access to the longer one but they can be levered off so may have been damaged. |
hi as stated above i have all ways fitted gates belts to all my vehicles and to my customers cars and never had one come back with problems over 40 years so must be good new vehicle purchase
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I always change the serpentine belt on buying a car, and keep the outgoing one in the boot, for the AA man to change if it ever does the worst! I changed my 4.4 one simply. It’s best to have pictures of the route it takes to hand as a guide. |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 205 ![]() ![]() ![]() |
Mine shredded yesterday too. So just ordered the two belts and tensioner and idlers get it all done in a oner
I’ll do a how to later today as once you know what to remove it’s not to bad only tool and hour to get it all back together 2012 Range Rover Westminster 4.4 TDV8
