Home > Maintenance & Mods (L322) > oil change today on the 4.2 3.000 miles
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
oil/oil filter /and sump plug today just done 3.000 mile change
 new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #629807 26th Apr 2022 7:44pm
Strider
England 2007 Range Rover Vogue SE 4.2 SC V8 Zermatt Silver
Cool lettering and chrome effect, deffo an improvement how did you do it Oggy?
Post #630228 30th Apr 2022 8:04pm
oggy
morning strider . the oval badge came of the back when i replaced it with new you have just to clean area up very good i use ipa cleaner . the v8 badge was just a bit smaller than the one on the cover so i had to remove the extra with a shanley it was the v only the 8 sat over the top okay . the supercharged is on a piece of alloy flat bar about 5mm thick and then cover it with carbon tape so the letters would stick better . i used black tiger seal or pu sealer to stick with double sided tape i put 10mm tape around outside edge of flat bar and them tiger seal right in the middle for a belt and braces job stuck down left over night with a little wait . just make sure that you clean the area only wear the badges are going to sit as the ipa takes or removes all the oil crap ect and can bleach the cover so mask up long job but i think it just lifts it when you open that bonnet bin on now for all but 12 month . when you come back next morning just go over with a heat lamp blower this will make the tape stick so much better double sided tape that is . i got the letters all separate then stuck them on one at a time peel back the cover paper and just put the letter on the edge of a stanley blade tip so you can fix them a little better or place them wear you need them to go just keep everything clean and wipe clean every thing will stick so much better . you did ask sorry for the sa new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #630266 1st May 2022 10:00am
Strider
Thanks Oggy for spending the time to reply with all the details.
That explains a lot, I was scratching my head trying to work out how it was done, especially the "Supercharged" bit.
Thumbs Up Thumbs Up
Post #630270 1st May 2022 11:19am
