![]() | Home > Maintenance & Mods (L322) > changing drive belts and pulleys 4.4 TDV8 a how to guide |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3345 ![]() ![]() ![]() |
Nice write up |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352 ![]() ![]() ![]() |
Thanks mate i hope it will help, its actually not too bad once you know the order of things saves a lot of money as well 2012 Range Rover Westminster 4.4 TDV8
Tdtj Member Since: 29 Sep 2021 Location: East kilbride Posts: 207 ![]() ![]() |
Thanks for the taking the time to do the write up as said on another post this will help me do mine this weekend if my parts arrive this week. 2016 4.4 diesel |
Glad it helped if I get time I’ll add pictures from the workshop manual if you need help just drop me a PM 2012 Range Rover Westminster 4.4 TDV8
Lol check your inbox every 5 minutes |
😂😂 2012 Range Rover Westminster 4.4 TDV8
Good evening gentlemen
Do you have the locking tool and spanner if so I set my locking tool so it was up against a fixed part of the engine and gave the spanner a whack with my rubber mallet and it started to undo hope this helps 2012 Range Rover Westminster 4.4 TDV8
Got the spanner but not the locking bit
Just take your time mate it’s not too bad once you get going 2012 Range Rover Westminster 4.4 TDV8
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Thanks for taking the trouble to do a write-up |
Hope it helps a few people 2012 Range Rover Westminster 4.4 TDV8
So together to a degree. Just need to put everything together Fan is on the cowling is resting there with it
👍🏼 2012 Range Rover Westminster 4.4 TDV8
