Home > Maintenance & Mods (L322) > Parking sensors AGAIN - Instructions for rear replacing
once the rears are activated then the fronts are as well... ... - .- -.
Post #63064 8th May 2011 7:33pm
stu
just been out and checked things. the front offside sensor is the only one that doesn't make a noise.
i suppose that that is the faulty one then.
i shall phone the garage in the morning and see if they will sort this out for me for free.
i guess that one faulty sensor stops the rest of the system from working properly then? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #63065 8th May 2011 7:41pm
M44K TS
I'm having problems with the rear sensors on mine, the fronts work fine as did the rears until 2 days ago, ever few seconds, the rear beeps as if there's something right behind the car. The car gets snow foamed and jet washed every week if I can although it hasn't been washed for 2 weeks now due to the weather.
Checked each sensor, they all seem to work but one of the sensors looks like the paint has bubbled on it, (almost like when powder coated aluminium corrodes and the paint flakes.)
The sensor still clicks like it should but I'm wondering if the paint could be causing the problem? I'll get some pics of it if I can. 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #64012 15th May 2011 12:04pm
T24RES
stu wrote:
hi, thanks for the reply.
does this check go for the front sensors too?
Yes it does Thumbs Up Ian
Post #64073 15th May 2011 7:24pm
