![]() | Home > Technical (L322) > Horrible noise |
Stoich Member Since: 21 Dec 2009 Location: Stornoway Posts: 36 ![]() ![]() |
Have had a few niggly problems with my 02 4.4 over the past two weeks but nothing serious until today.
I would have thought initially a seized pulley or something similar... |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
I had something similar on a p38. It was the ac compressor seizing. My Previous RR's!
That crossed my mind and I had the air con switched off just in case, but I assume the compressor will still be spinning anyway. The noise sounded like it came from the rocker cover area but it would be a relief if it were something like the AC If you like it, who cares what other people think |
Hoping someone may have some ideas on this. Currently with independent who has removed rocker cover but can't see any problem. No dealer / specialist on island where I live, so struggling to find answer.
Hi Vogue, how would you describe the noise.
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1529 ![]() ![]() |
Seems odd that it's kind of intermittent. Possibly rules out things like a collapsed timing chain follower. Could it be oil pump related? Wondering if at some point there could be some starvation hence the graunching noise? |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3813 ![]() ![]() |
very bad metallic squeel / screech - bearings running dry and collapsing |
rory_mcw Member Since: 08 Apr 2009 Location: Angus - Scotland Posts: 113 ![]() |
scrap it, £1500 cash!!!
Haha
i take it you found out i had been two timing you....................................
Result
