![]() | Home > Maintenance & Mods (L322) > Please Help! - 4.4TDV8 Intermittent Starting Problems |
Ajmngn Member Since: 25 May 2021 Location: Cambridgeshire Posts: 208 ![]() ![]() ![]() |
I'm at a loss and need some advice to troubleshoot why my 4.4TDV8 is struggling to start. Once started it runs fine. Here's the symptoms:
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
ignore me Cheers, Greg
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
I have had the same issue and I think I am at the tail end of it.
ffrr14 - thank you for this 🙏
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2745 ![]() ![]() |
I found an earth strap near the bottom of the right side rear (looking forwards) of the radiator, found when R&R'ing the fan shroud. |
So, I did the GraemeS mod yesterday and added a high-current relay into the circuit between the engine compartment fuse box and the starter motor. It has started without hesitation every time since and in as many different scenarios as I could try. It's only been 24 hours (but quite a lot of starts) so I need to keep an eye on this for longer to be certain, but I am quietly confident that this might well have done the trick. I will try and do a proper write up with some photos and a how-to that might get wiki-fied but, in the short-term and for this thread, here's what I did:
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1404 ![]() ![]() |
Its a common fix for starting issues on tvr chimaera and griffiths which seem to suffer from the same issues especially when hot... |
Yes, I can vouch for a hot engine seemingly making it worse. I often found that the vehicle would start when cold, even with a slightly lower battery voltage. I could drive for an hour so assumed my battery would be at full charge for its state of health, but then get a no start! It was infuriating! Anyway, no non-start issues so far and hope it continues that way long-term![/quote] Andy
Can remember more than once filling up the chimaera with fuel and being unable to restart the damn thing, having to go back to the garage cashier and get a push out of the way of the pump until it had cooled off a bit, then discovered the relay mod.
SBurke Member Since: 06 Sep 2025 Location: Clifden, Co.Galway Posts: 2 ![]() ![]() ![]() |
I am experiencing exactly the same symptoms and problems as Ajmngn set out so well and helpfully in his original post in my 2012 TDv8. In addition the vehicle will start if I go through the process set out in the post; Infotainment system off, AC off, ignition on for circa 20 seconds until all pumps (I think) run through there cycle and stop, and then start the vehicle.
you can try contacting Sam of Sams motors and machines he's a huge enthusiast and YouTuber and he lives in Ireland now
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 994 ![]() ![]() ![]() |
Andy, did you do a new post as a "How To" by chance, I can't find it ? |
I remember seeing this Edd China video at 6 mins and 50 seconds in - replacing the starter motor, he mentions two water tubes going into the starter motor and maybe they could corrode the contacts, anyway this caused him no end of grief trying to start his TDV8 MY11 in damp weather conditions
No, I never got round to it. However, I’ve found the photos I took at the time and can make a wiring diagram up with a ‘how-to’ this week when I have a spare hour. For what’s it’s worth, I haven’t had a single non-start issue since doing my mod. Not one. Yes, low battery can cause a non-start but this is well documented and the only control measure is a good AGM battery and carrying a jump pack for emergencies. However, the single strand ‘trigger’ wire for the starter solenoid is simply not up to the job in some cases for whatever reason. Having been so infuriated by mine being hit and miss when it came to starting, I can say with genuine sincerity that the starter relay mod is the single best mod I’ve done on mine. I cannot recommend it enough and even for preventative reasons as you never know how many starters are being changed out at great cost of time and money for no real reason other than a pathetic bit of wire. Andy 2010 4.4TDV8 Vogue SE in Santorini Black with Ivory interior 2017 Audi SQ5 3.0 V6T Quattro in Volcano Red 2001 Audi Allroad 2.5 TDI manual with low-range in Highland Green (Currently SORN whilst undergoing some serious restoration!) |
