Home > Technical (L322) > 4.2 sc radiator drain cock
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I wish I had never tried to drain my coolant using the radiator drain cock, after all it didn't work and I ended up removing the bottom hose,
Ever since I have had a leak from the drain cock that, so far I have been unable to stop, obviously I have not been able to find the correct o ring size.
The leak is starting to get worse so I thought a different approach is needed.
Does any body know if the drain cock is removeable and if so what diameter and thread do I need to replace it with a blanking plug.
Local indie says a new radiator required, that sounds over the top!
David Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #630844 6th May 2022 10:59pm
Classic888
If your radiator is part number LR021777 the drain plug is showing as available separately PYB500020. About £3.50. Hope this helps.
Look at: https://parts.jaguarlandroverclassic.com/p...and-rover/
Post #630954 8th May 2022 10:50am
bigbo
Many thanks but that radiator is for a disco 3/4 or a sport despite the description saying is for an L322
My radiator is a PCC500670 or PCC500370 and the plug is this less the o rings.
I will have another go at finding the correct o rings and whilst underneath try again to remove the whole assembly. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #631149 9th May 2022 11:52pm
