![]() | Home > Off Topic - Other Cars > Best adhesive/ sealant - repair hole in rubber door seal? |
I doubt whatever you do the end result will either not work or fail shortly after. I’d be inclined to bit the bullet and buy a new seal. |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1317 ![]() ![]() |
Have you tried super glue? 2018 SE SDV8 4.4 Byron Blue |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 608 ![]() ![]() ![]() |
How about a bicycle puncture repair kit, should do the job.
Thanks for the replies. A new seal is £771.66 plus VAT.
£771.66 plus vat. Good god, I’d live with the hole. |
That’s why I opted for a £1.50 tube of glue 😂 |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1236 ![]() ![]() ![]() |
I used something like this on some very flexible shoe soles, black and quite flexible, not too expensive if the current repair doesn't hold
Barmybrummie Member Since: 03 Apr 2021 Location: Somewhere in the valleys Posts: 767 ![]() ![]() ![]() |
A bit of black gaffer tape. Sorted!! |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
I would second Merchy''s suggestion for Stormsure adhesive.
Thanks for all the replies |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
use black pu sealer like tiger seal pump some in the hole and let it come out leave it dry till next day and then cut of surplus and shape it new vehicle purchase
