Home > Technical (L322) > gearbox service kit zf6hp26 question
dingg1
need to order a gearbox service kit , question is do I need the correct suffix following the 26?
how do I determine it?
2007 4.2 sc
tia
problem is I need to order from eu as in portugal , jack slipped cracking plastic pan so I'm Censored
Post #630176 30th Apr 2022 12:19pm
Mikey
LR007474 Thumbs Up
Post #630181 30th Apr 2022 12:51pm
dingg1
Cheers, sump pan and 7lt of zf lifeguard 6 on its way from amazon.de, 160 quid
Gearbox suffix is X I discovered Thumbs Up
Hopefully only the pan got cracked and no further damage occured Rolling Eyes
Post #630185 30th Apr 2022 1:59pm
garyRR
When I serviced my ZHP26, I bought the filter from D2P Autoparts (doesn't matter who you buy it from, it's the same part- the one in the green box).
The filter cost me £37
For the oil I bought Mannol AG55 (correct spec oil for a ZHP26). 8 litres cost me £46.
I also replaced the mechatronic seal and valve seal whilst I was at it, as both are prone to leak or cause issues over time. I got these from LR and both cost about £15.
The ZF service manual is available online as PDF and it is fantastic! It runs through everything Step by step in a flow chart and I just printed it off and ticked each item as I did it, to make sure the exact steps were followed in the right order. 2015 Range Rover Autobiography 4.4 SDV8
Post #630387 2nd May 2022 12:03pm
dingg1
Turned out only the pan was damaged, valve body not touched, (phew Embarassed) box was serviced 30000 miles ago, oil was quite dirty imo, no metal on magnets which was good to see, noticed they hadn't changed the mechatronic sleeve at last service, in hindsight I should have changed bridge seal and valve body seals, but thought about it too late, box has been changing no issues so hopefully it will continue to next filter and oil change Cool
Post #631309 11th May 2022 2:42pm
