![]() | Home > Technical (L322) > HELP bad engine sound! 4.4 TDV8 |
Dactonx Member Since: 14 May 2022 Location: United Kingdom Posts: 3 ![]() ![]() |
Hi all
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
I don’t know what it is, but it shouldn’t sound like that.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2731 ![]() ![]() |
Definitely not normal. Judging by the frequency it sounds as though it is occurring on a single cylinder. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
The garage you bought it from sound like bunch of lying shysters |
Cretosx Member Since: 03 Feb 2017 Location: London Posts: 7 ![]() ![]() |
The thing is, i'm willing to name and shame if anything isn't done but I travelled 3 hours to collect the car so going back and forth isn't really an option.
Cretosx as you are in London, not in the boonies like me, someone on here should be able to recommend a good garage or a good indy specialist in London. With a correct diagnosis, you could ask the seller if they will pay for repairs / collect the car and repair etc. I am sure your consumer rights could mandate this.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Take it back and get a full refund using consumer rights etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Thats not right by a very long way. It sounds very much like a cam / lifter issue but it really is not right.
No way is that normal take it right back ASAP. 2012 TDV8 Vogue (L322) |
QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 56 ![]() ![]() ![]() |
Definitely not right, I would say a piston my self, sounds a bit more than a tappet. Wouldn’t suggest driving far, in case more damage. Good luck with getting a satisfactory resolution. |
I would definitely heed QuebecTango's advice, personally I would not drive that car anywhere, it could end up with a lot more damage. |
I agree it sounds heavier than a valve / lifter but I feel it's too slow to be a piston, valve gear runs at half speed thats what made me head that way. One thing for sure it does sound nasty. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 286 ![]() ![]() |
Give it back and soonest before too much time passes. Hunt for a L405 is on. |
The 2015 consumer rights act means you can demand a full refund if you return it within 30days of purchase if it develops a fault. 2012 TDV8 Vogue (L322) |
