Home > Technical (L322) > HELP bad engine sound! 4.4 TDV8
Page 2 of 3 <123>
Dactonx
2011 Range Rover Vogue 4.4 V8 Barolo Black
Going to have car the car recovered back there, wish me luck.
Post #631821 16th May 2022 10:52am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Good luck BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #631843 16th May 2022 3:11pm
DrRob
Get your cash back if less than 30days. No brainer.
Hit them with a solicitor if needs be. www.defendingthemotorist.com
I can vouch for this company Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #631844 16th May 2022 3:39pm
JayGee
IMO I’d not budge from requesting a full refund and don’t be persuaded into leaving it with them to sort out. 2012 TDV8 Vogue (L322)
Post #631845 16th May 2022 3:51pm
DrRob
Ditto. Full refund and go.
Then name and shame Rolling with laughter Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #631885 16th May 2022 8:03pm
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
That has been worked on before.
They have cut the top of the fan shroud.
Was tempted to do the same myself when I need to remove fan again.
Post #631900 16th May 2022 9:43pm
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Re: HELP bad engine sound! 4.4 TDV8
Dactonx wrote:
Hi all
Bought this car a few weeks ago and the engine has started to sound awful, the garage I got it from is telling me it’s supposed to sound like it, what do you guys think the issue is?
https://youtube.com/shorts/nrX3O6QxEWk?feature=share
Desperate for help! Thanks
Interesting, I was convinced that was a video I shot until I saw your name at the bottom. I have a 2011 TDV8 4.4 making exactly the same noise. Someone has even cut off the top of the fan shroud exactly as has been done on yours.
I assumed it was a lifter problem but I've not managed to look in to it yet.
Post #631947 17th May 2022 11:29am
Mike Edwards
QuebecTango wrote:
Definitely not right, I would say a piston my self, sounds a bit more than a tappet. Wouldn’t suggest driving far, in case more damage. Good luck with getting a satisfactory resolution.
What do you think is wrong with the piston that would make a tapping noise rather than a terminal rattle?
Post #631949 17th May 2022 11:30am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Show the dealer this video, this is what a TDV8 should sound like, not that clattering yours makes.
 Christian.
Current Cars
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #631960 17th May 2022 11:55am
Hmmm, has anyone checked the injectors? Sounds like it might be a duff injector...
Post #632052 18th May 2022 12:01am
QuebecTango
United Kingdom 2011 Range Rover Vogue TDV8 Nara Bronze
Based my opinion on experience in commercial vehicle repair, where we have experienced similar “tap” which often turns out to be piston related. It’s possible that the piston has seized and the skirt has picked up. Seized due to a local overheat. Maybe oil cooling jet to a particular cylinder blocked or misaligned - if this engine has them. Have also known vehicles to run low on coolant and the same thing happen to the hottest cylinder ie no 4 or 5 on a straight 6.
This is of course an armchair diagnosis/opinion and could be completely wrong and have been! It would be nice to learn the outcome, but hopefully the vehicle will be returned for a refund, so this will be unlikely.
Let’s hope if it’s returned a decent repair is carried out before this vehicle is put back up for sale.
Post #632062 18th May 2022 5:38am
dingg1
Timing chain jumped a tooth and valve 'kissing' top of piston?
Any diesel smell in the new oil?
Post #632081 18th May 2022 9:06am
Mike Edwards
Have you tried disconnecting the injectors one by one on that side to se if the noise stops?
Post #632282 19th May 2022 9:59pm
Mike Edwards
Surely that would be a knock rather than a tap?
Post #632283 19th May 2022 10:00pm
dingg1
Not necessarily, happened to me on a bmw 325tdse, everyone thought it was an injector off, only became apparent when the head was off, didn't even bend the valve stem and just a small depression in the top of the piston Cool
Post #632302 20th May 2022 7:26am
Page 2 of 3 <123>
