![]() | Home > Maintenance & Mods (L322) > Rear Subframe Bush Replacement. BMW Bushes. |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
I will also post this on my project thread but thought I would put it in here as a reference.
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 401 ![]() ![]() ![]() |
I did this job on my old 3.6TDV8... I didn't rivet anything though... could you explain that a bit more as I'm curious ? Thanks Gavin 2005 Range Rover Vogue SE 4.2 Supercharged V8 Follow my 4.2 Supercharged antics - https://www.fullfatrr.com/forum/topic63354.html https://www.instagram.com/l322_supercharged/ https://www.youtube.com/channel/UC8ChHNSdscnJarKjBLd_IAg https://www.youtube.com/@ChallengingClassics |
As per the pics, the old bushes are actually rivetted to the subframe, I'm guessing this stops them slipping up and down. Perhaps it was a modification on later cars.
Ah, missed that in the pic.
Are yours BMW ones or LR ones? How are they sitting? Christian.
I fitted Meyle - as per this post https://www.fullfatrr.com/forum/topic54858.html Gavin
I saw that post before actually, would be interested to see how the BMW bushes are fairing. Christian.
The subframe had settled a bit and this caused the bottom of the bush to expose itself outside of the housing thus:
I got a Magnusson one from Screwfix, it looks like a pair of bolt croppers. Really difficult to get in there but manageable.
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 107 ![]() ![]() ![]() |
Have you noticed any difference with the new bushes in place? |
Back end is tight as a drum now. |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
How did you know they were past their best? Sloppy drive or an mot thing? |
They looked like they were degrading where the rubber meets the centre aluminium sleeve. Also the MoT showed them as an advisory and I wanted a clean sweep so I changed them Christian.
I have changed my rear subframe bushes now, I used the Landrover bushes, (fronts are different to the rears) and I used the BMW X5 removal tool.
