![]() | Home > Technical (L322) > Any TD6 Brake gurus? In need of some help. |
From the diagram below, the master cylinder feeds two circuits of fluid to the ABS block, which in turn feeds all four brakes, I can't find a hydraulic diagram but each hydraulic circuit from the master cylinder 'should' feed one front wheel brake and the opposite rear brake, with that in mind, it's unlikely to be the master cylinder if there is braking effort on both front brakes... is it possible that there is a kink in the new pipe or it's been trapped & crushed? can you blow air down it with both ends disconnected?
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 ![]() ![]() ![]() |
Hmmm that kinda woes out my idea of master cylinder then.
That was the diagram I was looking for - yes, you are correct, one thing to check is that the secondary circuit (rears) is being activated by the pushrod from the pedal/servo - is the master cylinder exactly the same as the one you took off in terms of the position of the pushrod before it makes contact? if the pedal is travelling halfway down as you say, it sounds like it's only got enough 'action' to engage the primary circuit to me. |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3984 ![]() ![]() ![]() |
I would be inclined to take the master cylinder off the car and bench bleed it. It’s possible the master cylinder isn’t full of fluid. If you have reasonable access you could do the bench bleed on the car, works just as well. Not sure about this but it’s also possible you have only refilled half the master cylinder when you topped it up with fluid. Usually the fluid reservoir has two chambers, you have maybe only filled one irrespective what the fluid level looks like on the side of it. |
Your a star!!
Thanks so much. I think the chamber is one. I have fluid on the side that looks fine. But yes I do see what you say about bleeding the cylinder. Peddle does seem to travel half way before it meets any resistance at all. As if the rod is 3 inch too short!! I will chase pipes back, but think I’m sure it’s the pipe coming out the furthest from servo that isn’t getting fluid out. (Which I’ve just checked and it is the feed for rears) Will try cracking the pipe on cylinder and see Thanks guys, slowly getting a little hope Accept, some days your the pigeon, some days your the statue! |
In the first instance you shouldn’t need to buy a new combination just try and bleed it off the car. Unfortunately you may have already introduced air into the abs circuit which you will still ultimately need to get rid of by running the abs whilst bleeding. |
Oh I’m confident I have/will haha.
There is one thing you could try re ensuring the reservoir is correctly full. Take off the cap and put it to one side, if you look in the hole you will see what appears to be a loose liner, with a pair of long nose pliers pull this liner up- it will come up halfway with a tug. Then check the fluid level and also add a small amount of fluid to see what happens. Not certain this applies to this car but l have come across others where the liner, which is in fact a coarse filter, has to be removed in order to fill a reservoir from new.
