![]() | Home > Maintenance & Mods (L322) > Auxiliary belt snapped again help please (Fixed I hope) |
Tdtj Member Since: 29 Sep 2021 Location: East kilbride Posts: 207 ![]() ![]() |
I would be chasing all the money for all of the pulleys if you’re swapping all back to genuine. They are useless to you or anyone else. I hope mine hold up. I’m so paranoid about it right now.
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352 ![]() ![]() ![]() |
just putting it all back together anyone know the fan mounting bracket bolt torques please 2012 Range Rover Westminster 4.4 TDV8
Well that’s not gone to plan, ffs 😡😡😡 changed everything for genuine parts and it’s gone again I’m stumped, I checked everything was running smoothly, I watched the belt on tickover and going through the revs for 15 mins all sweet, I did some short runs and checked all sweet, drove to work to pick up the trailer tent, jumped out of car and an almighty racket main belt gone again 😡😡😡😡😡 I’m totaly lost now as to what is causing this I checked all ancillary pulleys etc all ran smooth no movement at all the engine sounds sweet the only thing I did before the belt when the first time was to change the battery and tell the car I’ve got no charging issues no fault codes, any one got any ideas as I’m meant o be going away for whit week but after three belts I’m at my white end 2012 Range Rover Westminster 4.4 TDV8
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1361 ![]() ![]() ![]() |
I don't see any reason why they shouldn't be, but can you manage to get a straight edge and make sure all the pulley faces are aligned?
Are all the things it drives spinning freely ie power steering alternator etc in case its burning its way through and then flinging it off. Really strange one otherwise 2016 4.4 diesel |
I tested everything was spinning freely all bolts were tight nothing seemed loose only thing that is a constant is the engine was just above tickover, I 1st time I had drove 100 yards slowed due not turn and the main belt shredded the small snapped, then after replacing the parts I drove 2 miles again slowed down for a junction main belt went small belt ok, then after fitting genuine parts I drove 14 miles to work stoped then stated abs left it on tickover whilst I put the trailer on then it went making a awfull racket, ac was working fine alternator pulley spun freely, power steering ran smooth nothing happened prior to the first belt snapping it just went I’m lost as to what to do next bar taking it to a garage 2012 Range Rover Westminster 4.4 TDV8
Very strange. It’s turning out to be a very costly and time consuming exercise 2016 4.4 diesel |
Changing the pulleys and belts was simple enough in the end once I know how things went but three belts in such a short time is pointing to something else I just don’t know what it is 2012 Range Rover Westminster 4.4 TDV8
Bit if an update and opinions wanted please, I’ve been going over the belt fiasco and I’ve made a few assumptions and I’d like your opinions as to weather on not I’m clutching at straws.
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2768 ![]() ![]() |
Do not add washers - use only what is supplied with the pulley. However I feel that there must be another alignment issue or that the belt isn't routed correctly. |
When mine went it shredded the main belt but the small one stayed intact. I replaced all the idlers as yourself and the two belts
Tdtj I think you’ll be ok I’m sure it’s something else on mine mate
Yes mine seems to be ok
I hope so too mate we’re of to our Gaff in north wales Saturday for the week looks like I’m going in the van and wife in the Ds3 |
