![]() | Home > Technical (L322) > 4.2 SC Huge amount of gray smoke on startup - 118,000 miles |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Only on startup?
Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 114 ![]() ![]() ![]() |
Thanks for your reply.
Spoke to the garage and he thinks I've put diesel in it but would the spout from the pump fit the filler on a petrol car? Range Rover 4.2 SC
The diesel spout is bigger than the unleaded one.
I didn't run it for long and the smoke did reduce a little. I put about 45 litres in it to fill up.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3313 ![]() ![]() ![]() |
If they'd put the wrong fuel in the tanks there'd be a queue of broken down cars not far from the garage I'd imagine.
strongstuff Member Since: 26 Jun 2019 Location: North Wales Posts: 44 ![]() ![]() ![]() |
Have a look around your PCV valve, mine had a problem where it was sucking oil out of the engine through the valve and then into the throttle body.
The RAC have been and it's not diesel so I'm going for your PCV pipework recommendation as my Indie can't 'see' it for three weeks.
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Are stem seal a "a thing" on 4.2s? |
I don't know if they are but they would generate blue smoke i believe. Thanks for your thought though. Range Rover 4.2 SC
Dave lincs Member Since: 31 Dec 2021 Location: louth Posts: 42 ![]() ![]() |
Was it OK before you put fuel in? Whatever the RAC say have you checked your receipt |
Other than excess fuel, There’s only two things that an engine can burn to make smoke, thats oil or coolant.
A complete and utter cockup on my part. . .
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1399 ![]() ![]() |
This has to be a wind up, no one noticed that the oil cap wasn't on?
