![]() | Home > Maintenance & Mods (L405) > oil looking for some wisdom |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
You need to complete your profile, as no one will know which model / engine you have. No one can answer till then. |
aguiness Member Since: 13 Jan 2021 Location: glasgow Posts: 36 ![]() ![]() ![]() |
sorry about that i have now completed the profile
It seems that every website shows different results when looking
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3848 ![]() ![]() ![]() |
Find the Opie oil website, then put in your Reg No and it will show a list of correct specifications oil .
Hi
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1777 ![]() ![]() ![]() |
………. V6 Vogue - “Less is More” - less to go wrong! |
Hi
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1401 ![]() ![]() |
C1 is what you need 2018 SE SDV8 4.4 Byron Blue |
Thanks i have ordered the bellow
Is the oil I got ok or should I get something else |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 778 ![]() ![]() ![]() |
The one you have bought is correct for your engine. 5w30, C1 meeting Ford spec WSS-M2C934-B |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
This is the all-important number you need your oil to match sir... |
Yes. I run this in my 4.4 and have been using their oils for years. This particular specification I can take some credit for as I initially approached S&A back in 2018 asking them to consider producing it, which kicked off their development. 6 months later in early 2019 they launched it. Same goes for their transfer box oil to Shell spec TF-0870, which they now produce. Kev 2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey 2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey |
Cant thank you all enough
