Home > Maintenance & Mods (L322) > Would you use these parts on your transmission?
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
My TDV8 3.6 is running well and the only very small niggle is very rarely I get a harsh 2 to one change and a slight flare 4th to 5th. Most of the time all is smooth. I am getting bits together to change the mechatronic sleeves and seal with a fluid and filter change as after a lot of reading these seem to be a service item. The Car has done 135000 miles so I thought as the mechatronic body was going to be out, I would change the mechatronic solenoids or at least remove and clean them.
I found a set of Solenoids on Amazon clearance listed as new replacements at a good price, in the right colours, so ordered then. They arrived and are obviously not new. The seller stated they are remanufactured but after I complained the description was wrong they quickly gave a full refund and no need to return. The Solenoids came sealed and on inspection are spotless, with new o rings, I have tested the resistance and all are the correct spec.
Has anyone used remanufactured solenoids, I only found one short video showing testing and cleaning demagnetising etc which looked good.
They are now free https://www.youtube.com/watch?v=c3ZlLf5vkSQ 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #627859 6th Apr 2022 1:10am
wayneg
In answer to my question DONT TRUST THESE "recon" solenoids.
I did the fluid and mechatronic sleeve change yesterday and decided to take a punt on these free to me recon solenoids. I was going to do a double drain anyway so I thought there was nothing to lose. Thankfully I did a road test before the second fluid drop and the gear changes were horrendous. banging into gear, flaring, limited gears warnings. Put the old ones back today in the original sequence, with 2nd lot of fluid and instant butter-smooth changes. Maybe I needed to do something with the adaptations, I tried the road sequence a dozen times with no change. Lesson learnt thankfully with no cost apart from a couple of hours of my time. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #632753 24th May 2022 9:46am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Not sure I have the confidence to fiddle with an auto box as they are horrendously complicated. Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #632755 24th May 2022 9:54am
wayneg
Quite a straightforward process, now my box has new fluid and filter, the 4 tube seals a bridge seal and elec connector seal. So far with limited road use the random issues of 2 to 1 hard shift and a slight flair 4th to 5th are gone.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #632756 24th May 2022 10:02am
dhallworth
Things like dropping the valve block to change the bridge adapter and the 4 sleeves, or replacing the solenoids is pretty straight forward. If you need to, don't be put off doing that.
Personally, I'd not really want to go in much further though.
Post #632765 24th May 2022 11:48am
wayneg
Having done it twice ( once in reverse ) I would need a lot of info and reassurance before changing the Solenoids again. The Sleeve and bridge seals are easy enough. Maybe a ZF expert might elaborate on the Solenoid adaptation, is this doable? Also, Torx sizes go 27, 30, and 40. I am convinced ZF have their own size32? to make things problematic for DIYers 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #632771 24th May 2022 2:19pm
