![]() | Home > Technical (L322) > Radio Code |
Googs Member Since: 19 May 2022 Location: Tassie Posts: 159 ![]() ![]() |
What I mean is after you enter the 4 digits what do you do next? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
I don’t think it has a radio code.
This is what i have been doing, so I’m guessing that the radio amplifier is toast (in the boot)
The amplifier won’t cause this issue I don’t think. A couple of members have had the car do this after disconnecting battery, and I think the emergency deactivation worked after a few tries. Ignition on, and a countdown from 10 or 15 minutes starts… you wait and then should be ok. From memory that…
This is what I was looking for….
Thank you, i will give it a try just to get myself familiar with the system……a plastic bag aye, geez that inventive !!
Everything is controlled from the boot. The screen is literally just a screen, with a tape deck behind it.
So if the orange light isn’t glowing above the left side rotary knob does this mean the screen is toast or the radio amplifier?
So the orange light above the LH rotary knob is that controlled by the radio unit in the boot OR the screen ? |
