Home > Technical (L322) > HELP bad engine sound! 4.4 TDV8
Page 3 of 3 <123
Mike Edwards
United Kingdom 2013 Range Rover Vogue SE SDV8 Causeway Grey
Here’s the video that I shot of my own problematic engine…
https://youtube.com/shorts/M6KD0bGfgbM
Post #632828 24th May 2022 11:10pm
jagracer
United Kingdom 2011 Range Rover Vogue 4.4 V8 Zermatt Silver
I had that noise some years ago on a BMW Alpiner engine. It dropped a valvehead into the engine. Cost me another engine. Could not get the correct head, so had to rebuild another engine. It sounds like it has spun a crankshaft shell and run the crank bearing. The piston is kissing a valve, perhaps.
Post #632874 25th May 2022 4:09pm
johnboyairey
I would be looking to remove the serpentine belt, to briefly run the engine to prove its not anything to do with ancillaries first. but guessing by the shroud, that has already been done. but would set mind at rest. then with the fan not spinning, you have a chance to get a listening pipe into all the crevices, and especially around the exhaust manifold gaskets. so with a rubber hose, and small funnel over your ear, go around the engine, trying to find the loudest point. -crankshaft damper delaminating?
Post #632906 25th May 2022 10:13pm
JED
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Having very similar symptoms - same noise but no warning lights or fault codes.
@MikeEdwards - have you got any further with diagnosis or fix?
Post #636417 8th Jul 2022 7:43pm
Mike Edwards
Nope. I ended up selling it as it was.
Post #636425 8th Jul 2022 8:44pm
Page 3 of 3 <123
