Home > My Range Rover > New Wheels for me too!
This topic is locked: you cannot edit posts or make replies.  Down to end
Page 2 of 5 <12345>
M44K TS wrote:
I'd possibly be interested in your current wheels when you put them up for sale Thumbs Up
Once the new wheels are here and fitted and I've had chance to give mine a thorough spruce up (it's not like they're in bad nick as it is) I shall put them on the forum and PM you.
As a taster, they are the later model 20" wheels with the dimples (from a 2007 car), TPMS valves fitted (and working) and each tyre is identical, all Pirelli Scorpions, all with 4mm of tread, never repaired or punctured, no damage. The wheels are fully balanced (a MAJOR bugbear of mine) and simply ready to fit.
Will they fit your car? Think you may need newer nuts Very Happy Discovery 4 HSE
Post #63270 10th May 2011 8:38am
M44K TS
Great stuff Thumbs Up 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #63274 10th May 2011 8:48am
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
them new wheels are nice but the ones you have now are my favourite range rover wheel. 2004 black Vogue TD6
Post #63304 10th May 2011 4:57pm
Very nice Adam , Yep funnily enough i still have those Alloys , good choice tho Thumbs Up biggest PITA is trying to keep between the V spokes clean and free from brake dust , must be the longest set of alloys i've had Laughing Laughing Laughing
Post #63310 10th May 2011 6:11pm
RRCanuck
Canada 2010 Range Rover Supercharged Supercharged Santorini Black
+1 Thumbs Up
mike
Post #63331 10th May 2011 8:42pm
Avi
2006 Range Rover Vogue Td6 Alveston Red
RRCanuck wrote:
+1 Thumbs Up
mike
+2 Thumbs Up
Post #63335 10th May 2011 9:27pm
pretlove
nice wheels i think i prefer the ones you have but then i would say that as i have the same ones but without the dimples...still a change is good Thumbs Up
have you got a close up pic of your wheels as they look exactly the same as mine....where are the dimples? "RANGEISM WILL NOT BE TOLERATED"
Post #63337 10th May 2011 9:34pm
Very Happy Very Happy They've Arrived!! Very Happy Very Happy Discovery 4 HSE
Post #63438 11th May 2011 3:04pm
letsavit2
well go fit them then............ Laughing Thumbs Up 2004 black Vogue TD6
Post #63444 11th May 2011 4:17pm
Vogue
Adam, is there any difference in the offset between the two styles? As I have also changed different style wheels and found that some have 57mm, 58mm, 60mm and 53mm - the ones I fitted had more off set 58mm so sunk in under the arches which was somewhat annoying! 4 or 5mm didn't seem much but I noticed it.
Post #63451 11th May 2011 4:52pm
I have NO idea!
Is it stamped on them at all? Discovery 4 HSE
Post #63452 11th May 2011 5:01pm
Vogue
on the back / inside, usually it says something like 19 x 8j x 53et
the 53 is the offset in mm
19 is the diameter in inches
8j is the width in inches
this might be of interest, I started doing some research after I noticed the difference :-
www.driveaccord.net/forums/attachment.php?...1206194833
Post #63453 11th May 2011 5:06pm
Vogue,
Were you swapping sizes too? I doubt LR put any 20" wheels on that sit inside the arches and look luny and crap, and when I've seen these on other cars then fill out the arches nicely.
Hmm, fitting, I only have the standard scissor jack, that will be fun. Discovery 4 HSE
Post #63454 11th May 2011 5:09pm
Vogue
Hi Adam, no, some of the 20" FFRR wheels have a 53 mm off set (the same as the RRS) whereas other FFRR 20" have 57 or 58 mm off set (which goes slightly further into the arch - from what I can gather these are the earlier styles).
There was a post on here a few weeks ago re a gentleman who had put larger diameter size tyres on his std 20" wheels on a 2011 my - he mentioned that he could fit larger dia tyres as the offset was less on the later wheels as they were less likely to catch - I have done a search too but can't find it Rolling Eyes
Some of the Overfinch wheels I have looked at have a 50mm offset - hence they stick out slightly more...
Post #63457 11th May 2011 5:27pm
On the back of these it says
20x8.5J 58 (amongst other code letters)
I haven't taken the others off so can't see what they say, might have to leave it till the weekend anyway Discovery 4 HSE
Post #63461 11th May 2011 5:52pm
This topic is locked: you cannot edit posts or make replies.  Back to top
Page 2 of 5 <12345>
