Home > Technical (L322) > Car keeps cranking before starting?
Danwilderspin
Weird one - 4.2 supercharged and it keeps cranking before starting - left a good 10 seconds before I stopped it and then left it 5 seconds and it started first time both times on the second turn…
No I know these suffer from vsr and this is a sign of cold but it starts from cold fine this only happened when warm?
Any ideas? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633146 28th May 2022 9:17pm
Danwilderspin
Right this seems to happen hot and cold now - first crank I’ve left up to 10 seconds but turn off 1st crank on round two it starts, I tied initially cranking for 1 second then off again and round two it started.
Check the faults in the vim and I have a comfort relay fault - any idea where that is? I have a full spare fuse box for the front so if it’s in the front I will swap that first. Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633165 29th May 2022 4:29pm
Danwilderspin
Anyone have a relay diagram ? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633186 29th May 2022 8:22pm
dingg1
Try this, don't key all the way round to start position, jut put key to ignition on, leave for 10 seconds, then turn to start position, see if it starts immediately then...
Post #633189 29th May 2022 8:34pm
Danwilderspin
Yes that starts after about 2 seconds then I did it 3 times then did it instantly again and it took ages what are you thinking? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633225 30th May 2022 11:35am
Danwilderspin
Spoke to soon - did the same again just now after waiting 10 seconds so probably can rule that out Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633231 30th May 2022 12:20pm
dingg1
Fuel pump not priming the system adequately a possibility
Good luck, its happened to me a couple of occasions but fixed itself Laughing
Post #633242 30th May 2022 1:37pm
Danwilderspin
I have ordered a crank sensor as that is linked to the relay fault that came out.
Also at 130k it wouldn’t hurt to change it.
Is there a Schroeder valve to test the pressure? I’m not getting a fault? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633252 30th May 2022 3:28pm
Danwilderspin
My snapon reader reads the fuel rail pressure it seems… if I turn the ignition to POs2 after sitting for a bit it read 4kpa. If I turn it off and back to pos 2 it boosts it by around 50 each time, when it’s over 100 it seems to start… is it not priming enough or is ot a non return valve issue? If you get it over 100kpa and don’t start it the low slowly drops down Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633255 30th May 2022 4:56pm
Sandyt
Dan I had an issue with mine where it stopped and wouldn't restart and it was the pressure sensor on the fuel rail which was cheap as chips but only found out after re-placing the fuel pump in the tank might be worth changing the sensor
Post #633262 30th May 2022 5:43pm
Danwilderspin
Is that the small one with a vacuum line and a plug attached? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #633263 30th May 2022 5:47pm
Sandyt
Not sure Dan as it stopped outside the local garage I use for all our cars and just told them to fix it
Post #633272 30th May 2022 6:44pm
