![]() | Home > Maintenance & Mods (L322) > So here is what is lurking behind my sills and arch liner. |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 569 ![]() ![]() ![]() |
wow - Best one I've seen |
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
I am pleased to say the least. Still gave it a coat of stuff for precaution, thought I may as well while I was in there.
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1394 ![]() ![]() |
Has it had a sheltered life?
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 929 ![]() ![]() |
Rear arch liners are a pig to refit - trick I found helped no end was to leave them in hot sun for a good while which makes them more flexible to wrestle back in. |
Good tip on leaving in the sun.
No salted roads in Jersey |
redsportt Member Since: 31 Dec 2015 Location: n ireland Posts: 14 ![]() ![]() ![]() |
a lot of cold starts and engine not heating up properly is the downside of small island cars |
Tut is very true, but unlike my previous big Diesel engines, the petrol seems to get up to temp in about 2 miles! |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
you want to make sure that the drain slots in the sill to body panel are nice and clear i use a old hacksaw blade and slide up and blow them out with a air line . and remove all gromits along sill and spray some lanoguard in to the cavity this is nice and thin stuff and will not block the drain outlets if water is getting in it has to come out its when outlets are blocked and then you get the rot problems use a thicker protector on the outside i have used epoxy resin all in around my wheel arches and outer sills this will stop any more surface rust returning time consuming but job well done at the end new vehicle purchase
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 402 ![]() ![]() ![]() |
They really are in excellent condition |
