Home > Technical (L322) > Towing Equipment - Towing Prep ROW [028BR]
S80RTE
United Kingdom 2012 Range Rover Westminster 4.4 V8 Fuji White
I have been reading the build sheet for the TDV8 Westminster I am going to buy (hopefully) on saturday and I am wondering what " Towing Equipment - Towing Prep ROW [028BR]" means.
Post #633384 31st May 2022 7:32pm
rjff
I think you'll find it means that the loom for fitting to the towbar electrics has been installed and is ready to plug and play a suitable towbar kit.
Theere should be a gray socket on the rear bulkhead of the spare wheel well on the nearside.
You may need to tell the car that the towbar has been fitted if you are going to do so**, unless the car is coming to you with a 'bar already fitted.
** stops the reversing proximity alarm sounding when reverse is engaged with a trailer attached. Cheers
Richard
Gap IIDBT
Post #633398 31st May 2022 9:04pm
S80RTE
Many thanks for that.
Post #633400 31st May 2022 9:13pm
rjff
Hope it helps and let us know how you get on with the purchase.
AND pics of new to you FF are obligatory Thumbs Up Cheers
Richard
Gap IIDBT
Post #633401 31st May 2022 9:16pm
garyRR
All late L322s had the towing ECU fitted as standard and are "plug and play" with the correct loom.
You'll also need to tell the car through a dealer or IID tool if 7 pin or 13 pin electrics are fitted, as the late L322s monitor the trailer electrics for bulbs out. Not doing so will likely chuck up errors. 2015 Range Rover Autobiography 4.4 SDV8
Post #633979 7th Jun 2022 11:31pm
