![]() | Home > Maintenance & Mods (L322) > Fuel jet pump 4.2 |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
Dan
There's a good diagram in the WM under
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
It looks like what you say but what I don’t understand is why he said the jet pump side failed 😆 Current stable:
My suggestion would be to check the pipes, joints, and anything else you can think of for leakage and tightness, as well as any possible blockages.
Sorry if this is a really dumbe question but could I test this with buckets of water? Current stable:
I would think so as petrol isn't the best of lubricants, thus I would expect the pump to work without to much detrimental effect while you test it. Cheers
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 335 ![]() ![]() ![]() |
I'm not sure how it works or what breaks, but the pump only pumping from one side is a common fault and the solution is generally a new pump assembly - happened to mine years ago on the M40, resulted in a stranded wife! |
What’s the temporary solution keep over 70 miles in the tank? Current stable:
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Yes Previous cars:
