![]() | Home > Maintenance & Mods (L405) > Secondary turbo shut off valve |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3829 ![]() ![]() ![]() |
My L322 4.4 tdV8 CSOV was replaced under warranty.
Pat Member Since: 20 Nov 2016 Location: Airdrie Posts: 60 ![]() ![]() ![]() |
Hi Thanks for your reply. Its not the CSOV that the fault I have already had that out and tested. This valve is bolted to the back of the passenger side turbo |
Hi I will try and attach photo |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35693 ![]() ![]() |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Just out of curiosity what are the symptoms / error? Given it’s on back order might mean it’s fairly common. Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 778 ![]() ![]() ![]() |
It's item 5 in the below image. Part number is LR027196.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 827 ![]() ![]() |
That part number is superseded by
Also interested to know what the symptoms are ….. |
Hi thanks for getting back to me. My symptoms were a restricted performance warning every time i took car above 2800RPM. This is when secondary turbo should kick in but as the valve is faulty it was triggering a fault resulting in restricted performance mode. This was confirmed by a reputable independent LR specialist. The first garage I went to wanted £8100 to replace both turbos needless to say I wanted a second opinion and they told me after much investigation it was the "Turbine Valve" on the secondary turbo. This was confirmed in March 22 and as of today I am still waiting for them to get in touch when they receive the new valve. I contacted LR myself re the valve and they said I could order (and pay) for one but could not give me a delivery date. |
Not sure if the engine operation changed that much between the L322 and L405 from 2012 model to 2013
It is 2400 rpm on the L405 SDV8 also. Kev
So latest update on my turbo issue. Having been told I would have to wait forever on the part I need I decided to try for a used one from an online breakers. Got reply from a well known one via a phone call. Basically telling me that this part would not solve my issue. They guy said I had carbon build up on the veins on my VVT and only solution was to remove the turbo and have it completely refurbed (cost between £295 and £495). I suggested to him that it was only the primary turbo (Drivers side on RHD) that was a VVT and the secondary was a "normal" turbo. He then said if one was VVT then both would be. I am now completely confused.
You are correct. Only the primary is a VGT (variable geometry turbocharger) and this is the offside one. Secondary is fixed vane type and this is the nearside one. Kev
To visually clarify...
