![]() | Home > Technical (L322) > Strange whistling - hissing sound 3.6 TDV8 |
Dave lincs Member Since: 31 Dec 2021 Location: louth Posts: 43 ![]() ![]() |
Sounds like a turbo boost pipe leak |
jazzdude Member Since: 16 Oct 2021 Location: Limassol Posts: 26 ![]() ![]() ![]() |
How difficult is that to repair and is it likely to damage the turbo? |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1486 ![]() ![]() |
Have a good feel around the entirety of the chunky rubber hoses at the top of the engine bay. The two closest the front of the engine bay are the upper boost hoses. They're prone to splitting (you will need a good squeeze and finger to find a hole, if there is one, as it might not be obvious).
If you can find someone able to smoke test the induction side, that will pinpoint any leak(s), it may be a split in one of the inlet manifolds which is not unknown. |
It turned out to be a split in the driver's side intake manifold, so ordered both sides, hopefully, have them fitted next week. |
I had that with mine, ground out the split & about 10mm either side with a Dremel, cleaned with an airline and applied adhesion promoter, applied a good blob of Araldite Metal adhesive, heated to 30 deg. C. for an hour with a low power radiant heater - so far (over a month, with enthusiastic driving and a high pressure smoke test) so good, I know I'll have to replace it (or them) at some point but as a stopgap, it's a cheap fix. |
