Home > Maintenance & Mods (L322) > Replacement / recon engine needed...
DrRob
Playing devils advocate here....he might be saying engine has gone so he can buy it off you cheap, replace the cooler and then have a decent motor for pennies.... Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #633953 7th Jun 2022 8:08pm
Mistercorn
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Java Black
He has looked after my various Range Rovers for the last 10 years and always looks after me. He isn't doing that.
MC
Post #633987 8th Jun 2022 8:05am
DrRob
Defo worth changing oil cooler unit, gaskets AND the 2 O rings behind that feed into it (use Viton).
Flush coolant system, fit new coolant tank.
Hopefully that will be the fix Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #633990 8th Jun 2022 8:11am
JayGee
Not worth doing the oil cooler if the cause is something else and it now sounds like the garage know what's what with LR's. 2012 TDV8 Vogue (L322)
Post #633991 8th Jun 2022 8:19am
GraemeS
Australia
Can you take or drive it to the workshop where it was recently for a second opinion? Providing there's adequate oil in the sump and no water in the oil then the engine shouldn't be any worse off for the drive.
Post #633993 8th Jun 2022 8:42am
Mistercorn
Apparently the oil pressure was so low that the shells have been damaged and timing gear slipped a tooth causing valve damage. So it isn't looking good. If I can't find a very sensibly priced replacement I'll advertise as it and buy a newer one. I need one in 6 weeks for a trip around Spain so not going to hang about too long.
MC
Post #633995 8th Jun 2022 8:56am
JayGee
There are some nice ones advertised in the for sale section here at the moment which may fit your requirements 2012 TDV8 Vogue (L322)
Post #633996 8th Jun 2022 9:03am
johnboyairey
Secondhand engine for the 4.4 tdv8, is about £5k, plus fitting. Worth throwing some money at what you’ve got, if it’s still running, and driving.
Post #634001 8th Jun 2022 9:43am
