![]() | Home > Maintenance & Mods (L322) > Learning to change oil and filters |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1485 ![]() ![]() |
If sucking the oil with a pump, the drain pipe is next to the oil filler on the top of the engine.
Vipster Member Since: 09 Jun 2022 Location: Gloucestershire Posts: 12 ![]() ![]() ![]() |
Thank you. I see what you mean. The hose to which Sam connects the suction pump.
There is... the hose under the engine drains the sump when disconnected.
Wonder why the new design instead of the traditional sump plug. Is this more efficient? |
For that, I have no idea. I'm sure some will claim due to "cost" however, sump plugs are c.£1-2 and Ford did a pretty good job at re-designing and replacing the BMW things which didn't work on these cars, at presumably great expense, so, doubt it really is due to cost.
Thanks Gary.
I just remembered I actually did a step by step how to guide with pictures.
Thanks Gary.
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3843 ![]() ![]() ![]() |
Do the drivers side first, because that is always the dirtiest.
Well done and thank you.
