Home > Maintenance & Mods (L322) > Height sensors
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Height sensors
Had the suspension bongs go….first yellow, then red.
Max speed 30mph etc
All air out of the bags, and the car was on the bump stops
Like a pogo stick to drive
Suspension will raise when system had cooled etc….
But I could hear no leaking air
The compressor did not sound over worked
Managed to get a trolley jack under the front offside to have a look where I had a new air spring last august
Nothing wrong with air spring
But hello….what’s this I thought
The height sensor was obviously broken, with the link that runs from the forward lower suspension control arm to the sensor snapped, and freely hanging loose
Resulting in the suspension sensor being out of position giving cause for the suspension errors
A manual re-adjustment of the sensor, a bit of super glue and electrical tape, and the suspension works normally again
All error messages gone
All I can think is some road debris must have smashed the linkage whilst driving along
There is no guard to the linkage
Anyone else had the same problem ?
Post #634421 12th Jun 2022 5:48pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
was the joint free moving or stiff to move may have been seized joint they are not that expensive to replace new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #634430 12th Jun 2022 6:32pm
Breaking height sensors is a popular pastime for Range Rovers, they do it with great regularity... Hence the number of ones for sale on eBay...
It won't stay fixed for long so don't forget to change it, and have a good look and wiggle of the others... Thumbs Up Pete
Post #634432 12th Jun 2022 6:53pm
oggy
hi haylands i can remember reading some wear that someone took a long time but made them with rose joints and stainless steel
threaded bar i would say as long as you get your measurements spot on it would be a good upgrade new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #634464 12th Jun 2022 8:50pm
ergobyte
France 2012 Range Rover Vogue 4.4 V8 Java Black
Hi Rambles,
did you make a picture of that broken height sensors ?
As a reference for future victims ?
Cheers
Sylvain "it needs some intelligence to undestand you may not have enough"
Post #634543 13th Jun 2022 6:53pm
The originals last for years and don't cost a lot... I suppose if you're going to keep your fatty for ages it maybe worth it... Thumbs Up Pete
Post #634545 13th Jun 2022 7:11pm
oggy
hi pete i do understand what you are saying if they wear £100 side it might be worth doing oggy new vehicle purchase
previous cars .
discovery 1 200 tdi
discovery 1 300 tdi
Post #634552 13th Jun 2022 8:21pm
